carabalda
3671 Vistas, 10 Respuestas
MText Not Mirroring Like Other Objects
Something really baffling just started happening yesterday. I use the Mirror command all day, mirroring objects and text top create drawings of scenery for a TV show I'm working on. As of yesterday, when I mirror text and objects, the objects mirror perfectly on the Mirror Line, as expected, but the text shifts over, NOT mirroring on the Mirror Line with the other objects.
Look at the attached before and after screen shot: the left side shows four things selected to mirror (they are colored red for clarity). There's one piece of center-justified MText selected (the MIRRTEXT variable is set to 0, as always, because I never want the words to read backwards) plus one polyline (the diagonal lines indicating where door is hinged) plus one block (the door handle) plus one dimension. The capture shows me having invoked the Mirror command and ACAD is asking me to "Specify first point of mirror line" and my cursor is selecting the Midpoint of the double door opening: I want to mirror these 4 things on the center of the door opening.
When I specify the second point of the mirror line, 90-degrees straight up, the mirror happens, and the result is what you see on the right side of the screen capture: the polyling, the block and the dimension have mirrored on the mirror line perfectly, as always. But the MText is way off to the viewer's left, NOT mirroring like the other three objects on the specified mirror line.
I have no idea why this began happening, and I can't get text to mirror properly, as it always did until yesterday morning. Does anyone have any suggestions on how to fix this? It's making me crazy!
Etiquetas (3)
