pendean
en respuesta a: scoopthepoop2000
right-click on a dwg file in WIndows Explorer.
Select OPEN WITH then CHOOSE ANOTHER PROGRAM or whatever your version of Windows calls that last choice on the bottom.
A new pop-up appears: select DWG LAUNCHER and check the box that says something like "ALWAYS USE THIS PROGRAM"
Now manually start the version of AutoCAD you wish to use, then use OPEN command inside AutoCAD to open a file. Pan around, then QSAVE and close the file. Then close the program.
Windows will now remember to always use this version of AUtoCAD until you make the mistake of starting up the other one. But the fix will be simple: just manually start the version you want to go back to once to break the cycle.
You could just remove the older AutoCAD version from your PC and cure the problem forever.
