en respuesta a: Anonymous
sometimes the annotative objects get messed up. i think there are 2 annotation scales defined for the leaders.
switch in modelspace to 1:500 select all leaders that should not be visible and delete the 1:100 annotation via the properties toolbar .
switch to 1:100 and make the same for the 1:500 leaders.
an other possibility is to use OBJECTSCALE, select the leaders and make the same procedure, select the 1:100 and delete the 1:500 annotation and vice versa.
