399 Vistas, 3 Respuestas
Fillet in AutoCAD 2018
I had my own company for years using Autocad the last version being release 14.  Now trying to catch up on 2018, I find the fillet command to be challenging.  Is there another option besides holding the shift key down to make a corner?  Would like to just type fillet to continue working on getting corners to mend.
@Anonymous,
john.vellek has edited your subject line for clarity: Hello Kathy from Florida
rkmcswain
en respuesta a: Anonymous
Fillet has not changed much since R14. What exactly is the problem? Maybe show us with a screencast? [ https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast... ]
Are you working on 2D geometry or 3D objects?
MMcCall402
You can set the fillet radius to 0 and it will give you the same result as holding the shift key.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
pendean
Sounds like you have a radius set in your FILLET command: look at the command line for messages from the program.
