- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
recommended practice is to not use layer 0 for drawing. this is one of the reasons why. There is only one layer 0, you dont get an xref layer 0.
reading your statement, "When I turn on and thaw 0 layer, lines on it (drawn in current file) shows up, but lines on 0 layer in xref doesn't."
can you clarify, provide a screencast or example drawings? The typical behavior is, that if layer 0 is on, anything within the base file should be on, as well as anything on layer 0 in the working file. what layer is your xref inserted on? that could affect it as well.
https://knowledge.autodesk.com/community/screencast
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
