Juergen_Becker
en respuesta a: CWilcoxson
normaly there is no S::Startup in AutoCAD only in AutoCAD Mechanical etc.
Maybe it's defined in ACAD.LSP, ACADDOC.LSP or ACAD.MNL. Please check that.
When you find it please post the content here.
When you use only AutoCAD you can delete. Be carefully maybe there is a PlugIn which use that method.
Regards Jürgen
BTW: I never migrate AutoCAD. For me it doen't work correctly.
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
