Alfred.NESWADBA
en respuesta a: CWilcoxson
>> I did migrate settings from 13
Then you might have transferred a tool/app/... which might fail on 2018.
>> When I switched it to vanilla the drawings seem to be opening normally
Again a proof that not standard AutoCAD makes it slow, it's one of your customizations
At least you have found an environment, that is clean, I would start now to copy that profile to make it my new working profile ... then add step-by-step the modifications you added and watch when the slow down starts.
>> some of the ACADM aliases but those seem to be working
Are you working with plain (Vanilla) AutoCAD or with AutoCAD Mechanical? ... as ACADM (for me) means AutoCAD Mechanical ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
