CWilcoxson
en respuesta a: cadffm
So: Have you defined the function?
What is the content of that function? I am not sure. See below, does this qualify as defining a function. I did migrate settings from 13 when I installed 18.
I checked and the profile was not set to vanilla. When I switched it to vanilla the drawings seem to be opening normally but my ribbon was different.
The only thing I can think of that I customized would be a ribbon panel with 8 custom buttons I created. These did go away when I switched to the vanilla along with a couple of other panels. I did also changed some of the ACADM aliases but those seem to be working fine even though they don't show up in the PGP file when vanilla is current.
