- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Changing splines to polylines
hi. I'm working with ACAD 2004. I have a spline I would like to convert to a polyline. I've seen numerous posts saying this can be done using the PEDIT command. If I try to follow those instructions, I get a message telling me that what I selected was not a valid polyline.
Can someone tell me how to do this with my antique version of ACAD?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
do you have express tools? You can flatten a spline and it will convert it. I dont think spline conversion using the polyline command was added until recently
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not with AutoCAD 2004.
If my remembering is correct then yo might save your drawing back to DXF12, that converts splines to polylines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can convert a spline to a polyline with the splinedit command. I am not sure if the command is available in 2004. After giving the command input the P option (polyline)and then enter the level of smoothness you want. If the original spline lies on a plane a polyline will be created. If the spline did not lie on a plane you will get a 3dpoly. You can convert a 3dpoly to individual lines with explode.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Copy the spline to a new file .dwg
Save the new file as ... in version AutoCAD R12/LT2 DXF .dxf
Close file .dxf
Open file .dxf
Copy a polyline from a file .dxf to an old file .dwg
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I attempted to install express tools using the install disk but it wasn't in the list of features. I can change an arc to a polyline but not an ellipse. An arc doesn't give me the area I need. (I'm laying out an aircraft instrument panel.). I'm going to see see if i can generate an arc that has an area close to half an ellipse. I'll get back with results.
Jim
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Splinedit does exist in 2004 but the P option isn't one of the options.
