680 Vistas, 3 Respuestas
LTSCALE doesn't work sometimes
I have several lines in xref which have line type -----w------ and ------san------- and so on.
The display correct in xref file but in the current file, some of the linetypes doesn't show up no mater what the settings of LTSCALE is.
The current and xref files were built with the same template. What could be the possible reasons?
en respuesta a: Anonymous
They just show up as continuous lines.
-FDC-
Did you get an SHX error ?
Maybe PSLTSCALE will do th trick or try changing the VISRETAIN variable.
It can also be a simple solution, maybe the ltscale was set (changed) in properties (in the Original file).
pendean
What are your settings for LTSCALE, MSLTSCALE, PSLTSCALE and CELTSCALE exactly?
In XREF and in your top file.
