- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Xref Quit Working
I select attach xref and the box opens to select a file. I select the file and then click open. Once done the autocad seems as if it has frozen. If I hit the ESC key the cross hairs come back. If I hit the enter key the reference file attaches, however the dialog box never showed itself. The FILEDIA is set to 1 and the CMDDIA is also set to one. i have closed autocad and shut down the computer and still same results. please help. thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
referencing to your AutoCAD version please install the last service packs and updates .
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please ... ( as a try ) try to draw a simple rectangle in a empty dwg and attached it as an xref in another new dwg file and tell us if it's happend again ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Do you have multiple monitors? If so, the problem could indeed be that the 2nd dialog is off screen. You could try the steps Dean mentioned above, or disconnect the 2nd monitor and see if the dialog reappears on the main display. I have this happen when I try to use my laptop with an external monitor, and set the external as the main display.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
