cadffm
en respuesta a: Anonymous
Now you show totally other things, A3 is now A2 and you compare pears(mm) with apples(inch).
Lineweight=ByLayer=>'IRF B1'/'IRF B2'
Layer 'IRF B1/B2' Lineweight =0.50mm
DJ500 A2 Scalefactor =1.22
1.0 / 1.22 =0.81967
lw0.50 x 0.81967 = ~lw0.41(units)
T830 A2 Scalefactor =29.8
1.0 / 29.8 =0.03356
lw0.50 x 0.03356 = ~lw0.017(units)
Your "Layout" is ~695units in X-Axis (thats well for mm)
now you said thats inch, 695inch.
Your printable paper size in X-direction is 23,4"
and you want to fit your Layout (695) into that Paper (23.4),
The factor is 1/29.8=0.033556
too small for your printer and your eyes.
The problem ist not the printer.
the problem is that your Layout is not build in/for inch.
Use mm in Plotdialog or create a inch-fit Layout (scale all by 1/25.4).
*all numbers are up and down rounded, it was´nt important for me*171214_lw1.png
Sebastian
