dgorsman
en respuesta a: Anonymous
There's a problem with scaling line weights for printing, in that they scale linearly.  If you set up the full size to print with "good" values, shrinking them down proportionally for a half-size drawing results in very little difference between them.  If you set up for the reduced print, when you print up to the full size there is too much difference.  So I work with two plot styles, one for full size and one for reduced size.  The first has a little more variation in the middle weights, while the second has fewer actual weights but a more noticeable difference between them.
Of course that only applies to physical paper copies.  PDF and electronic printing should always be printed at full size.
