BeKirra
en respuesta a: Karol-Or
@Karol-Or wrote:
Again cannot, although i think i made it simple.
Now i saw that it wasn't closed, and i closed it with the properties dialog and it worked.
But why wasn't it closed? i made it with 2 splines that i snapped each other to continue, and used lines.
To answer your question above, it'd be simple if you properly setup "osnap" or "osmode" before drawing lines.
To fix your problem and create the extrusion, I prefer to convert all lines into a closed pline and agree with John as "flatten" is something like "explode". It "converts" spline into pline.
Therefore the procedure may be
1. use "trim/extend" to ensure the end points of lines/splines are met.
2. use "flatten" suggested to make spline to pline.
3. use "joint" to joint all lines and plines so they will be converted into a single closed pline.
4. then you'll be able to create an extrusion.
5. now holiday is not far away. Emoticono muy feliz
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
