Alfred.NESWADBA
en respuesta a: Anonymous
which layout do you try to plot?
Layout1 has an assignment to HP-OfficeJet-K7100 and uses a plot-style-table "stippel.stb" (which we don't have, so maybe that is the reason why I can't reproduce the issue.
You might to to plot to "DWG to PDF.pc3" without using the STB and see if that result is similar to my attached PDF.
If not please upload your PDF as well as the STB file.
Also important: which version and service pack of AutoCAD do you use...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
