- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> Every tho i run on a fresh install.
>> I have 'reset all back to default'.
Just to make sure: new installation does not mean that the AutoCAD profile was reset from the prev. installation.
But as you were creating a new Windows account that seems not to be an issue of the AutoCAD profile (as long as you don't start AutoCAD with an ARG-file as profile).
From your first post
>> I run on a brand new windows 2010 installment,
From your last post
>> Also my frameworks is the latest version.
Which Windows 10 are you running exactly?
Which Framework is the last you see as installed?
When you open that dwg created by AutoCAD 2017, is that always the same dwg-file (so this issue could be a file-specific one) or a dwg-file created with some tool/application (so it might have proxies including and not struggling with/without object enabler)`?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
