Alfred.NESWADBA
en respuesta a: Anonymous
>> I want to be able to view the shapes in realistic mode
The screenshots do not give us any information about what type of objects these are, lines, polylines, 3D-solids, surfaces, 3D-faces, ...
The dwg-file would tell us a lot more about what you have.
But only real 3D objects with at least surface informations can be rendered, e.g. 2 parallel lines do not know that they are connected by a surface between them. So the visual style "realistic" does not show you anything filled.
You need to have meshes or surfaces or 3D-solids.
For your geometry you should create the rectangle at Z = 0, a polygon with 6 sides on Z > 0, then use command _LOFT and select both polygons.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
