12-06-2017
09:50 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-06-2017
09:50 AM
thank you for your data!
I have now copied the SHX into a folder listed in the AutoCAD's support folders.
Then I
- created a new drawing,
- loaded this linetype,
- created a layer with your linetype
- created one line and one polyline, assigned these objects to the layer from prev. step.
- created a new palette, drag and drop these 2 objects to the palette
- closed the drawing
- closed AutoCAD
- started AutoCAD with a new drawing (that has this linetype not defined)
- drag & drop the line into the drawing ==> I can see the linetype
- drag & drop the polyline into the drawing ==> linetype works well
So with AutoCAD 2018 Update 1.1 I can't see any issues, only one time it was necessary to run command _REGEN.
The only idea I have is that you don't have the SHX file within a support folder.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
