john.vellek
en respuesta a: TECHSERVICES
Hi @TECHSERVICES,
I am a little confused by your description of your issue. If the Viewport is locked you are indicating that you can zoom in it? Do you mean the actual scale of the view is changing?  Is it possible to attach your file to a post so I can see what you are seeing?
You might check to see what layer the viewport is on (and whether or not it is locked) and you might also check to see if it is actually an xref or something else.
I am happy to take a look if you can share it.
John Vellek
