- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I GOT A VPORT THAT I CANNOT WINDOW PICK TO ERASE... ITS LOCKED BUT STILL ZOOMABLE.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What happens when you click onto it?
Or is the viewport's border not visible? ==> in that case look for layers frozen or turned off.
If you can select the viewport's border, but using <DEL> key does not remove it it might be on a layer that is locked.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @TECHSERVICES,
I am a little confused by your description of your issue. If the Viewport is locked you are indicating that you can zoom in it? Do you mean the actual scale of the view is changing? Is it possible to attach your file to a post so I can see what you are seeing?
You might check to see what layer the viewport is on (and whether or not it is locked) and you might also check to see if it is actually an xref or something else.
I am happy to take a look if you can share it.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Could it be that it's on the DEFPOINTS Layer [bad but common practice] and Layer 0 is either turned off or frozen? That would have the effect you describe, if I'm understanding correctly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
mview layer was locked... i scrolled thru my layers prior and didn't notice...thanks all!!
side bar: is mview a common layer name for non.printable vport windows?
