Kent1Cooper
en respuesta a: g.stratoudaki
@g.stratoudaki wrote:
.... It is very urgent to me to find a lisp so to ... describe 2 segments with continuous linetype  and the other 2 segments with dashdot linetype. It's not usefull to me to exlode the polyline in 4 segments because I want to count one object ....
That is, as @cadffm said, simply not possible within one Polyline.  You can make the Exploded result into one object by defining the pieces as a Block, as I mentioned at the end of Post 4, but whether that is useful depends on what you want to do  with it as one object.  For instance, you will not be able to see its overall length in the Properties box, as you can with a single Polyline, nor do certain editing operations on it [e.g. Offset/Trim/Extend].  But if all you need it to be one object for is to be able to manipulate it all together in certain other ways [e.g. Move/Copy/Rotate/Array], a Block could be a workable solution.
Kent Cooper, AIA
