571 Vistas, 3 Respuestas
Open a file from the tool bar
I have a problem with AutoCAD 2011. When I go to File-Open it goes to a menu box on screen asking for an address. Will not go to my files. Any solutions?
BeKirra
en respuesta a: Anonymous
Do you mean that "menu box" is the command line prompt?
If so, cancel this command by pressing "Esc" key.
Then type "filedia", press "Enter" key.
Enter "1" then press "Enter" key.
You should be fine.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
ennujozlagam
@Anonymous hello, can post some screenshot. or go to command prompt type FILEDIA set value to 1. thanks
en respuesta a: ennujozlagam
Thank you, thank you, thank you. Worked perfectly.
