Test.1.01.cer.2002
993 Vistas, 2 Respuestas
NETWORKSRF not working
I am trying to create a surface with the attached splines. When using the command, it says that a network surface cannot be created with the selected curves. I do not understand what I am doing incorrectly. If this cannot be done, are there any workarounds?
Thank you to anyone who can help.
en respuesta a: Test.1.01.cer.2002
You can fix it, Change Spline to polyline by using SPLINEDIT command.
I attached DWG fixed.
en respuesta a: Anonymous
I've had the very same problem - and many others - with AutoCAD.
