en respuesta a: GrantsPirate
I have tried typing in exactly (setenv "MaxArray" "200000"), and other similar things. I have also tried just typing in set..., setenv etc, to see what suggestions pop up above the command line, but the only similar suggestion that comes up is setvar, which does not recognize MaxArray. I know that many different Autodesk help pages say that the setenv command and MaxArray should work, but I have had no luck on several different Autocad versions that I have tried (2015, 2018, mac, PC...). I also notice that the gridlines do not cover a very large area. In the version of Autocad that I worked with in the past (no longer have access to that computer), the workspace was infinite, and I had several 6mm x 6mm arrays in one layer with ~200000 objects each. Is Autocad LT better for 2D drawings than Autocad? I tried asking these questions to the sales people at Autodesk, but they do not seem to be very familiar with these technical details.
