en respuesta a:
07:30 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-24-2017
07:30 PM
The first Check, Click Your dimension, and then prompt command PROP.
Then You can see the object of properties.
So, Check Text override value.
The second check, Go to the Dim style, In Primary Units, Check Scale Factor.
The Scale factor multiplies your dim value when you create dimension.
