Alfred.NESWADBA
en respuesta a: MatTheDrafter
>> had to do a new installation of AutoCAD
Which version of AutoCAD?
The background of the question is that your issue is based on 4K displays and that is supported since 2017 Update 1.
Older versions of AutoCAD can either use a lower display resolution (so it's not the preferred resolution for your display) or set the Windows text scaling (dpi scaling) back to 100% (or max. 125%) which results, when full display resolution, that the text is quite small.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
