Alfred.NESWADBA
en respuesta a: Anonymous
>> and the problem arises from the object type
That's what I was waiting for ... :cara_guiñando_un_ojo:
"Size" can be very different, depending on the object type. Is it the 2D projected length or is it an area or is it the extents-value of an object, what is in CAD a "object size"
"Position" can be very different, as a line can have a startpoint which is equal to the endpoint of another oriented line, even if they are laying one on top of the other
"identical properties" can be critical when you have one time a circle and the other time a block with a circle
So when you can exactly define what is equal from your point of view someone might be able to give you a step-by-step workflow or maybe knows a tool or writes a tool that can do that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
