11-22-2017
12:44 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-22-2017
12:44 PM
Annotative scaling may be hiding annotative blocks. Might try ATTDISP setting as ON (usually as NORMAL, switch it back after).
FYI, the "incrementing number" for generating selection sets is nothing; it's just a sequentially generated ID. You would assign the result to a LISP variable for walking through with (ssname ...), or perhaps counting with (sslength ...). You might wrapping that (ssget ...) test call in the latter and see how many objects are actually in the drawing.
