itorhitec
1065 Vistas, 10 Respuestas
pan and zoom problem with with tablet with pen
hellow,
we have a problem in autocad with 3 tablets that we use autocad 2017.
the problem is the the pen loses the grip while using the pan command.
also in zoom +- command. we of course checked the touch  in the lab. and tryied another pen.
can you tell as if the problem is within the autocad. and if so how to fix it.
pendean
en respuesta a: itorhitec
AutoCAD for desktop is not specifically designed for pens on touch-screen tablets. Maybe by R2020 or R2025.
What's that tablet?
itorhitec
en respuesta a: pendean
the tablet is Panasonic  fz-g1 , it also happens after windows update.
S.Faris
Try Calibrating using CAL - CALIBRATING
SALMANUL FARIS
itorhitec
en respuesta a: S.Faris
when i run "cal" command it opens callculator
S.Faris
Type TABLET(enter)
can you see CAL now?
SALMANUL FARIS
itorhitec
when i use tablet command
@S.Faris wrote:
Type TABLET(enter) - i get messege "your pointing device
cannot be used as a tablet"
S.Faris
Is TABMODE set to value 1 already?
SALMANUL FARIS
Alfred.NESWADBA
@S.Faris
The tablet commands you are referring to are for those types of tablets:
They have nothing to do with tablet-computer systems.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
S.Faris
en respuesta a: Alfred.NESWADBA
oh ok. My Bad. I thought they are related to the tablets.
SALMANUL FARIS
itorhitec
i tryied it , the value remain 0.
