11-20-2017
10:45 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-20-2017
10:45 PM
Thanks for uploading the file . from the first attempt i use from Dimension tab ( Aligned ) and i have proper dimensions ( in black ) . ( see attached image )
Note :
- Purge ( Regapps ) your drawing because you have 27 registered applications deleted.
- set current DIM_1 dimension style.
- once you make first dimension from Dimension > Aligned command you can continue from Dimension > Continue.
- see attched CAD file .
is this fix your issue ...
Imad Habash
