Alfred.NESWADBA
en respuesta a: 20719085
>> Also I suspect it's due to the dim style? Because I have no problem using the system default dim style
>> but when I match property with the one that office uses this time, all measurements
>> became 100 smaller now..
When you create a dimension and this dimension sees modelspace entities it stores the viewport scale as scale-factor for the dimension value.
If you use match properties this function does nothing else then also transfer this scale-factor from one drawing to another one ... that is not specific to your dimension style.
I would just recreate the dimension with "better" object snaps.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
