966 Vistas, 16 Respuestas
AutoCAD for Mac in German
Will be released AutoCAD for Mac also in German.
If so, when?
wispoxy
en respuesta a: Anonymous
Download the .exe language pack, then convert the .exe with apple's 'Wine Converter'. That's what I do for my mac laptop.
So google / look into: mac wine converter, mac WineBottler
https://www.winehq.org/
http://www.davidbaumgold.com/tutorials/wine-mac/
http://winebottler.kronenberg.org/
Laden Sie die EXE -Sprachpaket , dann wandeln Sie die EXE mit Apples 'Wine Converter " . Das ist, was ich für mein Mac Laptop zu tun.
So google / Blick in : mac Wine converter, mac WineBottler
en respuesta a: wispoxy
Thanks for your help.
I can the File open now but they can not be installed.
The button AutoCAD is blocked with the message it is not installed.
Can you help me again?
wispoxy
You need to use wine / wine bottler first, and it will turn into an installer.
I have already converted the file.
The Problem is the installation menu.
I have a screenshot attached.
T
wispoxy
Can you please translate what that pop-up say's?
"Interne Fehler - Ungültige parameter empfangen" = "Received invalid parameter - Internal error"
wispoxy
AutoCAD doesn't like the directory that file is in. Where do you have it?
I have the Mac 2015 version installed normally.
The program is located in Mac OSX in Programs folder
under Autodesk and is called "Autocad 2015.app"
wispoxy
I'm not concerned about the AutoCAD location, I'm concerned about language patch location.
wispoxy
Wish I was there to do it for you in person, it's not easy when you're the one not seeing the computer yourself.
wispoxy
If you speak German, I would call AutoDESK support in germany and ask why they don't have a language pack for AutoCAD mac users. Even if you do or don't get it to work with wine / winebottler.
Germany
(Eastern European Countries, Germany, Hungary, Lichenstein, Poland, Russia)
Autodesk GmbH / Autodesk Media and Entertainment
Aidenbachstr. 56
81379 München (Munich)
Germany
Phone: +49-89-54769-0
Fax: +49-89-54769-400
Autodesk GmbH
Luxemburger Str. 105
NRW
Huerth-Efferen
50354
Germany
Phone: +49-2233-20530
Fax: +49-2233-67587
Autodesk GmbH
Hindenburgstrasse 46
Ludwigsburg
71638
Germany
Phone: +49-7141-702970
Fax: +49-7141-7029780
Autodesk GmbH
Forsterweg 3
Potsdam D
14482
Germany
Website:  www.autodesk.de
Phone: +49-331-88988-10
Fax: +49-331-88988-119
Autodesk Media and Entertainment Phone: +49-89-6144750
Autodesk Media and Entertainment Fax: +49-89-6144755
The location of the patch file is the "Download" folder.
I'll call the support next week.
Thank you for your efforts and contact informations.
wispoxy
No problem. And I wish you much luck.
Hallo Phillip,
hast du eine Lösung für eine Deutsche Version auf dem Mac gefunden?
Würde mich über eine Antwort freuen.
Grüße
Rolf
pendean
No solution yet: no German language variant exists for MAC.
Hallo Rolf,
ich habe die deutsche Windowsversion unter "Parallells" auf meinem Mac installiert. Da die Macversion etwas anders vom Programmaufbau ist und ich mit der Windowsversion lerne war dies die beste Möglichkeit.
Parallells kann ich dir nur empfehlen. Es läuft sehr gut. Weit besser als ich erwartet habe. Ist allerdings kostenpflichtig.
Mit freundlichen Grüßen
Philipp Huber
