11-19-2017
02:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-19-2017
02:37 AM
AutoCAD measurement x 100 times when dimension in layout
Hi there fellas,
I'm having this very weird problem where I'm trying to dimension everything on an A3 layout that contains various scaled drawings (in order to keep text height at 2mm). When I first used dimension it worked correctly. Because there is a dim style in the office I match property to get the newly created dimension to match the one we are using. Then I use addselected to mark another distance. However, the distance showing up as 100 times bigger than it should be. And if I use it to addselected it gets another 100 times bigger... (see image below)
Has anyone come across with this problem? What's causing it and how can it be solved?
Cheers!
