leeminardi
en respuesta a: jcsteele560
Chris, I don't think we are understanding each other. Given 3 points with lines going through them at a given angle, it is unlikely that the 3 lines will intersect at a point.  Let's say the angle of your line 3 going through C were slightly different.  Line 3 would no longer pass through D but lines 1 and 2 would.   You couldn't make line 3 pass through D (which cannot change due to it being defined by lines 1 and 2) without changing its angle or moving point C. It is not a question of AutoCAD finding a solution but your problem statement, as I understand it, makes it an impossible task.
lee.minardi
