Alfred.NESWADBA
en respuesta a: jcsteele560
>> Is there any way in which I can have the lines lying on the points without
>> upsetting the point position or angles between the lines?
If line-angles are fixed and the point-positions are fixed then just use command _MOVE, select each line and move the line from (objectsnap) endpoint of the line to (objectsnap) node to the point.
If you expect all 3 lines to meet in one intersection point ... then no, I don't see a (mathematical) solution for that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
