- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
As you say, this is the same reason why I do not want to go to 2015. There is also another very important reason which is that I do not upgrade something which gives me all what I need just because autodesk issues a new version every year without any benefit to my purposes.
Any way, it seems that I did find a solution. I decided to install 2015 as a separate installation in order to examine if moving to 2015 is not so painfull and if it will resolve the issue. Installation failed in mid proceccess and there was an error message stasting that I have to install .NET 4.5 if I want to continue with the installation successfuly. I found .NET framework 4.7.1 in Micropsoft site and installed it. Than I checked again Autocad 2014. It seems that for the time being the issue was resolved.
So, thank you for helping. If the problem reappears I will post a message on this thread.
Thank you again
P.S. as far as I know I am not on subscription
