- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi guys
I'm not sure if this is the same issue or not. We are having a problem with the DWG to PDF 'printer' not recognising our true-type font in 2018.1.1
It worked fine in the original 2018 installation.
The font we are using is called Dotum, which I believe is not a default Windows font anymore, but we can still install it locally & use it.
Product Version 0.49.0.0 AutoCAD 2018
Product Version 0.154.0.0 AutoCAD 2018.1.1
I've read a workaround is to convert text to geometry, but a fix to revert back to how it worked before would be good.
Let me know if it's an issue not related to this & I'll start a new topic.
Cheers
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @adrian.calabria,
Yes converting all the text to geometry is one option to retain its use. I understand how you would prefer to keep it intact. Can you share a copy of this font so I can test on my side?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is this a copyright font, one that you purchased? That may be the actual reason.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
John, attached are the 2 fonts we have installed. We started using it in Windows 7, but then it was excluded from Windows 10.
pendean, as mentioned above, it was a Windows font in 7, but removed in 10. And it works with 3rd party printers like CutePDF.
Also, on further troubleshooting, I found that with the DWG to PDF, if I only untick the 'capture fonts' box & leave the 'convert to geometry' unticked, it works AND the pdf file size is a lot smaller.
Ultimately, because Windows don't support this font anymore & therefore why should I ask Autodesk to do it, that may be the answer. Because although as humans we all want things to never change & work the same way forever, changing a setting and saving people some time for more important things is the way forward.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"TrueType Collection. TrueType Collection (TTC) is an extension of TrueType format that allows combining multiple fonts into a single file, creating substantial space savings for a collection of fonts with many glyphs in common.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@pendean is correct that the TTC files might be the problem. I used this site to convert them to TTF for you. I hope they behave better.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
