11-14-2017
10:45 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-14-2017
10:45 AM
Are you all a "put everything in one DWG file and run LayerStates for each page" kind of firm? AutoCAD isn't designed to automate plotting with those personal choices, so Alfred's tip is one way to work with the tools already in the program to speed publishing/plotting up.
For dates: did you remember to use a FIELD? designed for automation if you chose the correct option. If not, you can always use the harder way with FIND command to replace one with another.
