cadffm
en respuesta a: Anonymous
a)
It's very strange to print a plan with several different layerstates
can you tell us more about it?
Usually you have your own drawing number if the content is different.
Otherwise the way Alfred describes him would be the actual procedure, independent of Publish (thus also for single print over PLOT).
b)
dates table / drawings - You know the FIELD function and use it already, or not?
If so, what kind of problems do you have?
FIELD Type plotdate and fieldeval set did you?
a) Only with a specially agreed way would this work (additional program),
but only with the full version.
Nothing out of the box.
Specially tuned, I mean that all the necessary information must be present.
In the simplest case:
There are always 8 layerstates and the names are known.
Sebastian
