Alfred.NESWADBA
en respuesta a: Anonymous
>> However, one part is still black as it used to be but it should be green
Am I correct assuming you had a black box and green cylinders, then you started command _SUBSTRACT? .... and so you have got mixed colors.
Select all objects, change the color to e.g. red and then back to bylayer, this worked for me with your drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
