- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a drawing in AutoCAD 2018. Model view shows colors of the drawing as it's defined in layer. (I don't override colors for individual objects in properties.) However, if I create a new layout, colors are different. My layer properties manager says it's white. (I don't override it on per layout basis.)
First strange thing is that it says white but shows black. (This screenshot is from that layout.) (In model, layer manager says white and shows white.)
Then when I click on VP color of active layer in that layout, I see really white is selected. So I can't understand why it shows black next to white in layer manager.
Other strange thing is that one of the component is in gray but every single layer is defined the same way in terms of VP color.
I tried other solutions people said it solved their issue but I didn't had any configuration "wrong" as they said. (I also am sure that the layout is active so the settings for it are fine - because I can, e.g., hide some layer and it really hides it in the layout.)
Please what could be an issue ?
Thank you
¡Resuelto! Ir a solución.
