Karol-Or
1874 Vistas, 6 Respuestas
Can't align UCS corretly to an object
I want to align one of the axes to the line.
The origin now is on the line.
I use align UCS to object but it doesn't align the axes
john.vellek
en respuesta a: Karol-Or
HI @Karol-Or,
I rotate the UCS on the Z axis. Is this what you are looking to do?
John Vellek
Karol-Or
en respuesta a: john.vellek
I don't mean that line, the vertical long.
I attached a clean drawing
paullimapa
Try the UCS and 3Point option (as shown in attached png):
1st point is intersection
2nd point is endpoint of long line
3rd point is endpoint of the angle line
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Kent1Cooper
I believe what it's doing is using an endpoint of the Line as the new-UCS origin, but using the Line's extrusion direction  for the axis directions from there.  Since a Line is not "locked into" the XY plane of the current UCS when it's drawn, it can have a Z-direction difference between its ends, with its extrusion direction not perpendicular to its length.  It doesn't define a plane, but it still has an extrusion direction from when it was drawn.
Instead of using the OBject option in the UCS command, just pick two points on the Line [you can specify a third point or <accept> its assumption for the last prompt], and the X axis will be aligned with the Line's direction.
Kent Cooper, AIA
Karol-Or
en respuesta a: Kent1Cooper
I never understood the Extrusion Direction, how is it created?
Kent1Cooper
It's a unit vector representing the direction that the Z axis "aims" in World Coordinates for an object.  If you Extrude something with a positive extrusion distance, it's the direction that extrusion extends from the object; or, if you give something Thickness, it's the direction the thickness extends.  If you're drawing in the WCS, everything's extrusion direction when drawn is 0,0,1 [or, as expressed in entity data lists, (210 0.0 0.0 1.0) -- it's also the VLA "Normal" Property].  It will be different if something is drawn in a UCS whose XY plane is not parallel to the WCS XY plane, or if something has been Rotated 3D-wise from its original drawn position.
Some things [e.g. 3DPolylines] "have" one, from when they were drawn, that's kind of meaningless from the point of view of setting a UCS, since a 3DPolyline does not define one and can't be given Thickness [although you can Extrude one -- you get Surfaces rather than a 3D Solid].  Some things [e.g. non-planar Splines] don't have one at all.  Lines are peculiar because they can have delta-Z difference without  their extrusion direction being perpendicular to a plane they lie in, the way it must be for many object types [Circles, Arcs, 2D Polylines, Text].
Kent Cooper, AIA
