- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> Learn the key board commands it will make you better at you're job
If you start telling CAD newcomers that they need now a new list of words to get known to a CAD system then these people massively fail whenever changing to another vector edit (CAD like) systems (independent of Autodesk products like Fusion360, 3DS-Max or systems from other vendors) as they even don't have a command line or any option to start commands by typing (maybe there exists some shortcuts).
Not any new CAD system (excluding the AutoCAD based products and AutoCAD clones) use command calls by typing.
>> I know every command and I don't even need Toolbars up to do anything
Wow, even saying that needs a lot of self-assurance. If you really know every single command by name in AutoCAD I guess you are the only one in the world.
Speaking about AutoCAD you'll need to learn then > 1400 commands, if anyone needs AutoCAD Civil 3D means again another 800 commands (don't know the exact number).
You might have a great memory for words and it might be easy to learn words, you might be one of those learning foreign languages in very short time, but please recognize ... finding a button (and not knowing how the command is exactly written) is much easier for newcomers than to know the exact command-name. Especially in none English versions the command names are translated and shortened (not logically shortened) and that is much more complex than finding a button.
>> now everyone thinks they know CAD cause they can click a button
I'm more than 30years with AutoCAD, and I know how to teach people so they know how to work with the structure of AutoCAD without knowing every single command name ... they are allowed to pick the command from ribbon and toolbar(s).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
