Kent1Cooper
en respuesta a: rob.aHH2T8
I don't quite understand....  I'm not sure what you mean by "parameters."  If "similar to" the image, would it be not quite the same, and can you draw [even an approximation of] what would be different?  Did the image use a Hatch pattern?  If it used Lines and you just want a Hatch pattern that would do that, it would be very easy to define -- what are the rib width and spacing?
Kent Cooper, AIA
