alangerhans
2277 Vistas, 11 Respuestas
After I save I can't move text/dimensions
Hello, I've been searching for a solution to this problem but I can't find anything.  I have a drawing that I am working on, and when I save it the text becomes uneditable, and the dimensions wont move when I select them.  In order to fix it, I use the audit command, and that causes all the arrows on my leaders to unattach from the text.  I've tried other files, and they work fine, but if I copy and paste my drawing into the working file, it starts doing it again.  I've attached a portion from the file and I am having the problem in it.  If you open it, save it and then try to move the drawing.  I appreciate any help, oh and I'm using autocad 2018
