rob.aHH2T8
3310 Vistas, 3 Respuestas
Metal roof hatch- boundaries as parameters
Is there a way to create a metal roof hatch that uses the upper and lower boundaries as paramaters?  It would look similar to the pic below... Vertical lines are easy, it's adding the upper and lower parts or something similar that use the upper and lower 'y' boundaries that's the problem.  Need to use the upper and lower because all roof heights are different, right.  Thanks!metal roof example.jpg
