Since you probably do not want to buy a program from me to correct the problem,
how does it look with the described solution/workaround of me in Post 8 Tested? Is working?
Have you also looked at the many general notes on the block?
DWG -Purge Regapp
Annotation of ATTDEF/ATTRIB isn´t senceful in this kind/Block.
Blockbasepoint under LookUp-Parameter-Grip
Current LookUp-State is Custom and display metric&imperial at the same time, same place
 ('custom' is good for ??? what?)
Please let us know what happened to our help and the block definition, thank you.
dbroad
"It's really confusing to label a lookup table as visibility."
Yes, but for this Block and the function below it is a very well label for this parameter.
I hate it more when 90% DynBlockCreaters (  ) did not named the Parameters and Actions with a senceful label.
Sebastian
