In addition to what the others have said, both blocks have problems.  There are several parameters that have no grips, and several lookup tables. There is a visibility parameter that is uneditable in both versions of the block.  The formula field attributes don't make sense to me.
Another thing that doesn't make sense is that your units are meters but you are using Architectural Length formatting.  Both drawings should be recreated with better designed blocks and a better thought out units scheme.
As another has said, if you use annotative blocks, you won't need to scale your blocks.
Architect, Registered NC, VA, SC, & GA.
