11-08-2017
03:58 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-08-2017
03:58 PM
@christianbaileypaulsen1
I don't know too why the Link to the Insert is broken.
The old inserts based on an different Block version,
so your explaination created 300 inserts/SAVEinDWG2013/CLOSE/REOPEN is NOT true for this uploaded file.
Or you mean with "inserted about 300.." not create by command:insert (or by Toolpalette), instead copy&paste from another File.
In DWG there is tons of garbage, that does not create confidence, we do not know what files, commands were involved.
Fixing is often not possible by Acad command, only with appropriate program extension. But in that case, you can just re-create the attributes. Change the 4 attdef to constant, use attsync, set the attributes back to non-constant and apply attsync again.
OT: And why the Attributes are annotativ - only with one scale / 1:1, no sencefull function, or?
@dmfrazier
Why crazy?
Thats the good possibility of formular-fields, unfortunately, no fields can be nested in DIESEL fields.
@dmfrazier
Why crazy?
Sebastian
