- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@imadHabash wrote:
Kent1Cooper wrote : DIMTAD was already zero in the example drawing, but DIMTVP was not.
from the example drawing in the OP ... DIMTAD = 3 .
I'm sure I got that 0 from somewhere, but now I don't know what I was looking at.... But while it's 3 in the drawing at large as you open it, if you set the Style of the drawn Dimension current with no overrides, it's [still not 0, but not 3 either] 1.
Then, drawing another Dimension in that Style doesn't have that big offset in text position, because that's caused by DIMTVP, which applies only when DIMTAD = 0. It's 1 in the definition of that Style, but that drawn Dimension has six overrides in Extended Data, of which presumably one is that DIMTAD is 0 instead of the Style's 1 [I think it's the (1070 . 77) (1070 . 0) pairing in Xdata]. That would have caused the drawing's DIMTVP value of 2.5 to affect that Dimension.
DIMTVP as a numerical value doesn't seem to appear in the Properties palette -- just the resultant displaced text position.
TO FIX that displaced-text one, in Acad2016 or later, you can use -DIMSTYLE > Apply, or in earlier versions, DIM > Update.
